![]() | Home > Maintenance & Modifications > Defender Seat Frame |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 837 ![]() ![]() ![]() |
Is this before you fit the seat frame in place, i.e are you trying to move the runners by hand? If so then I suggest fitted them to the seat box and testing the movement with your body weight on them. The last thing you want are loose, rattly runners and they should free up a bit once used anyway. How often do you actually move your seats in normal use?
Zapo Member Since: 22 Feb 2023 Location: Basque Country Posts: 15 ![]() ![]() ![]() |
So, I tried both, I tried to move them before putting them in place, which allowed me, after gorging it well with WD40 to move it a little by hand, but even once put in place, with the weight of my body (maybe I should get a bit more fat?) I think they'll settle with time, but I'd like to free them a little all the same, without feeling like I'm forcing them too much.
I do think they'll come together over time, but I'd like to free them up a bit all the same, without feeling like I'm forcing too much. I move them relatively little, the driver a little, to get access to my fridge trap. But sometimes, when I'm on a long trip, I move it forward a little to force myself to have a straight back. |
