Home > Maintenance & Modifications > Rust converter
Naycrx
Rust converter
Good Afternoon
Is it it possible to make your own rust converter? For example like kurust? Heard it being done for a fraction of the cost diluted with water
Post #1048738 15th Oct 2024 2:03pm
BrickBox
It’s not worth the hassle. Just buy some ACF-50 and it’ll kill most of your rust issues. 2008 2.4 110 Utility Station Wagon XS.
Post #1048746 15th Oct 2024 3:10pm
Use dilute phosphoric acid (25% w/w) which is widely available and inexpensive and will turn your ferric oxide into ferric phosphate.
Post #1048752 15th Oct 2024 4:11pm
Dinnu
For smaller / manageable parts, I remove the bulk of the rust using electrolysis - google is your friend to find how it works. After electrolysis, I then use a rust remover (not converter). For rust removal I use a product manufactured by Hg - https://hg.eu/uk/products/hg-rust-remover
Its not expensive, and I only brush it on, and a small 500ml bottle goes a long way.
On my restoration thread there are 2 pics after I applied it to my chassis. But was only surface rust it had to deal with. Nevertheless always pleasant to see clean metal.
https://www.defender2.net/forum/topic72365-135.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1048807 16th Oct 2024 1:56am
AMBxx
How well does electrolysis work? I suppose that in theory we could connect our Defender chassis to a trickle charger of some sort and spray part of the chassis with an electrolyte.
Just make sure it's plugged in the right way round!
Post #1048832 16th Oct 2024 10:21am
Dinnu
With that method, you would need your cathode only a film thickness away from the chassis.
I think Ed's China method of dipping the chassis is much better, the difference is that the electrolyte would literally cost pennies.  1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1048862 16th Oct 2024 1:53pm
AMBxx
I 'just' need to spend £20k on Evaporust!
Post #1048866 16th Oct 2024 2:40pm
