Home > Tdi > Elring Head Gasket - No Hole version |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1606 |
You’d be fine with the one you’ve bought on an old Tdi, I’d be worried if it was the other way round. It’s not going to make that much difference in the grand scheme of it. The MLS gasket is a much better gasket.
14th Oct 2024 11:16pm |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 173 |
The MLS gasket is better. If you originally had a no-hole gasket and now have a 2-hole, I'd be measuring the piston protrusion to make sure it's allowable. The difference between gaskets is 0.2mm. Also measure the gasket to confirm, 2-hole should be 1.4mm thick LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com |
15th Oct 2024 10:02am |
