![]() | Home > General & Technical (L663) > 110 Boot Space |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1444 ![]() ![]() |
Coming from a D4, the boot size is a shock! Eiger Grey MY23 D250 SE with bits. Known as Noddy.
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2188 ![]() ![]() ![]() |
total waste of a 'clean sheet' design...........pretty sure my "old" Def has more useable boot space
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1217 ![]() ![]() |
The New Defender 110 has a smaller usable boot space than the Freelander 2, I once drove !!!!
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3428 ![]() ![]() |
I have the 90, the 110 has acres of boot space
![]() Excluding the tyre on the door the Velar is actually a bit longer than the 110. Defender 110 - 4758mm Velar - 4797mm I suppose they had to fined a way to justify a 130 24MY 90 D250 HSE, Tasman Blue |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 242 ![]() ![]() |
Yes, compared to my D3, the boot in 110 one is a hand's breadth shorter, in the D3 things rolled freely around there in every curve, but here too, and my dear beagle called Din doesn't even notice it...and that little bit less makes it aesthetically charming...and really a little bit more manageable...so for me...it's perfect...and I like big boots...I don't have a 90, which was my passion without a doubt, just for that reason!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 215 ![]() ![]() |
I was shocked at the beginning. ( coming from a Caravelle no boot is big enough
![]() It’s not deep. They have preferred to give more leg room to the rear passenger. It would have been nice to have an adjustable rear bench. However there is more vertical space. And it’s all very usable. I have managed 6 large (airplane) trolley. And 3 small cabin trolley. At that point I have stopped saying the boot is small. |
