![]() | Home > Puma (Tdci) > 2.4 intercooler hose slipping and whooshing |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2161 ![]() ![]() |
Make sure the inside of the hose is very clean and free from oil, also make sure the spigot on the turbo is very clean and free from oil. Brake cleaner is useful for this.
Regarding hose clamps. The HCL super torque or MIkalor ASFA High torque clamps are good and can take 11-12 Nm, which should be sufficient to retain a clean hose on a clean turbo spigot. https://hcl-clamping.co.uk/collections/high-torque-clamps-1 |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
Many thanks, I have ordered some of those clamps.
The hose is new, so any oil will be recent. I do remember seeing some oil when I removed the old hose though. What is the best way to clean the spigot? Do I need to remove the turbo? |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 172 ![]() ![]() ![]() |
Clean the spigot with cloth sprayed with brake clean.
No need to remove the turbo, just spray spigot with brake cleaner from below and above, it evaporates pretty quickly. Any bits you can’t get to with spray then spray on cloth and wipe. You can spray the inside of the hose as well, or spray on cloth and wipe.
many thanks, I have just done that, albeit with the same clamp for the time being (waiting for new ones to arrive). From what I could see, it all looked quite clean to me. Will keep a close eye on the hose and see if it moves again over the coming days.
