![]() | Home > Maintenance & Modifications > Air con front |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 530 ![]() ![]() ![]() |
I used the air con front shroud and the original bonnet shut, but I did have to make it fit, not that you’d tell.
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 408 ![]() ![]() ![]() |
Looks great mine is Keswick also, what did you do to make it fit?
Cheers |
Thanks! When the bonnet is opened I had to pop rivet two pieces of tin to the bonnet panel to extend it, then I was able to screw the sticky out grill to these.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3529 ![]() ![]() ![]() |
Should not need to do anything to the slam panel. My 2012 has AC from factory, and the slam panel does not look any different from my 1988 90.
Just 2 little brackets on the lower end, see: https://yrmit.co.uk/product/pair-s-s-mount...-defender/ 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Got it sorted. Had to slightly realign the passenger wing.
