Home > Maintenance & Modifications > Air con front
Oldyellar
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Air con front
Can anyone tell me if it is just a case of fitting the aircon style shroud to get the aircon look or do you need to change the slam panel? Thanks
Post #1048415 11th Oct 2024 8:36pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I used the air con front shroud and the original bonnet shut, but I did have to make it fit, not that you’d tell.
Post #1048418 11th Oct 2024 8:52pm
Oldyellar
Looks great mine is Keswick also, what did you do to make it fit?
Post #1048430 12th Oct 2024 7:14am
MarkBrown
Thanks! When the bonnet is opened I had to pop rivet two pieces of tin to the bonnet panel to extend it, then I was able to screw the sticky out grill to these.
Post #1048434 12th Oct 2024 7:37am
Dinnu
Should not need to do anything to the slam panel. My 2012 has AC from factory, and the slam panel does not look any different from my 1988 90.
Just 2 little brackets on the lower end, see: https://yrmit.co.uk/product/pair-s-s-mount...-defender/ 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1048438 12th Oct 2024 8:14am
Oldyellar
Got it sorted. Had to slightly realign the passenger wing.
Post #1048491 12th Oct 2024 11:08pm
