Home > Td5 > Reinstating the TD5 10p EGR kit
Biscuits
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
MOT is over due on the old Defender, booked it in and before they stuck it on the ramp said "the EGR has been removed, gunna fail without one mate". That and the E-marked LED headlights "chinese cr@p with no kick-up"....
So, couple of questions. Can anyone give me a point in the right direction for the parts I'll need to reinstate the EGR please ?
Will order WIPEC H4 healights, think they look classier than LEDs anyway.
Many thanks
P 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black
Post #1048326 11th Oct 2024 10:03am
Jim1988
Be easier to find a different test centre!!!
Post #1048332 11th Oct 2024 10:59am
Biscuits
That has crossed my mind ! 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green
Post #1048334 11th Oct 2024 11:04am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
My reply would have been "No problem mate. I'll go somewhere else"
Jim
Post #1048335 11th Oct 2024 11:13am
Ianh
The testers only doing their job correctly, as part of the MOT they have to do a visual check to see if an EGR is present.
Someone presenting a vehicle obviously with an EGR removed could be from VOSA checking MOTs are being done correctly. So the MOT tester could get into a lot of hot water if they pass the vehicle.
I think it was very good of them to highlight the issue(s) prior to the test. They could have just tested it, collected the fee, and failed the vehicle, putting the op in a much worse situation.
Post #1048337 11th Oct 2024 11:27am
Biscuits
I agree @Ianh, they've done the right thing. I just need to "fix it" 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green
Post #1048338 11th Oct 2024 11:29am
Ianh
Follow the attached link and choose the correct diagram for your TD5, you can then see what is missing on your vehicle and the relevant part numbers
https://www.lrworkshop.com/diagrams/land-r...irculation
Post #1048339 11th Oct 2024 11:42am
markb110
If looking up parts on EBay add Discovery to your search description as there is normally more spares available for the TD5.
Post #1048345 11th Oct 2024 12:59pm
Biscuits
So.... looking at the LRW site there's an EU2 and EU3 option on the TD5.
At a guess, the EU2 is 10p and EU3 is 15p.... but.... Land Rover.... so who knows ?! Both cover 1987-2006.
Have to say, I seem to remember my car being an EU3..... but it's a 2001 10p 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green
Post #1048349 11th Oct 2024 1:16pm
markb110
Mines a 2002 (52 plate)
Its definitely the latter version.....................i have the bits in the garage to prove it Whistle
Post #1048374 11th Oct 2024 4:31pm
Biscuits
The research gets more mistifying the more I do lol
Looks like I've found the vacuum actuator (although only one, not two as per the schematic online)
And I'll need to be Mr Tickle to get the EGR pipe on the exhaust manifold !
Post #1048376 11th Oct 2024 4:40pm
landy andy
The early ones were single valve the other unit being filter i thought.
Later EU3 were two solenoid
Post #1048388 11th Oct 2024 5:57pm
Martin
Site Admin
Do you have the updated centre dash console/switchgear - if so likely to be 15P/EU3.
If the earlier type centre dash then 10P/EU2.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1048389 11th Oct 2024 5:59pm
landy andy
You will also know by how many electrical connections you have on the inner wing for solenoid/solenoids.
Post #1048391 11th Oct 2024 6:09pm
