Home > In Car Electronics > What is this connector for ?
happierdays
United Kingdom 2015 Defender 110 Puma 2.2 SW Scotia Grey
Hi
I have been looking to wire in DRLs to my Puma. I know I need an ignition live, an earth/negative and a feed from the side lights to turn-off the DRLs when the side or headlights are in use.
I had a poke around the engine bay and found this connector fitted with a plug and un-used. It was mid-way along the left-hand side of the engine bay (in line with the air intake), with two wires, one black and one white. Happily it is ignition wired.
I would appreciate help on two questions:
1/ before I use this connector, does anyone happen to know what it was supposed to be used for (just trying to ensure it will support the current and not blow out a fuse) ?
2/ can anyone advise what the connector type / description is, as I'd rather use the proper connector that simply cut the existing one off ?
Many thanks in advance
Post #1047893 6th Oct 2024 3:45pm
Martin
Site Admin
That's the engine breather heater pipe connector, only fitted on extreme cold weather specification.
The white wire is a 5A fused ignition supply.
See here, it's "Riscaldatore tubo di sfiato motore" top middle Smile
https://www.lrworkshop.com/wiring-diagram/...e-controls  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1047902 6th Oct 2024 4:52pm
happierdays
Brilliant. That's super helpful. I doubt I'll be doing any extreme cold weather modifications, so will connect up to that ! Thank so much Thumbs Up
Post #1047904 6th Oct 2024 5:00pm
PaulMc
This is the mating male connector -
https://www.auto-click.co.uk/7282-5575-10
. Paul.
Post #1047907 6th Oct 2024 5:17pm
happierdays
Thank you Paul ! Really appreciate the help - another project to complete next weekend Very Happy
Post #1047909 6th Oct 2024 6:11pm
