Home > Maintenance & Modifications > Removing fuse blade |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 855 |
Youโll have to disconnect the battery before you go putting anything (metal) in the fuse holder. The only thing that comes to mind is a tweezers or something with tiny pullers. 2008 2.4 110 Utility Station Wagon XS.
6th Oct 2024 8:45am |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1186 |
because of the burnt spade end, it may have welded itself to the fuse box ??
6th Oct 2024 10:38am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
The safest way would be to try and unlock the pin from the block holder, they usually have a tab that locks them in, and the the fuse post slides into the receptacle.
It might have melted into the fuse holder / block though that is the trouble but, if need be you probably can even get a new terminal if you need to as long as you can get it to fit the block okay. The locking tabs are probably best accessed from the top rather than rear, as mentioned isolate power first from the entire block. The locking tabs will either be one side of the female spade or both sides opposite one another. Youโll need a thin piece of metal like a knife blade that isnโt sharp to get it down the side that is small unsought of you can buy connector key sets that one can be useful for. Those are ATO blade fuses which is the most common on the market, you just need to identify the connector type and locking tab style. Somewhere like 3 way components will likely have them. Good luck. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
6th Oct 2024 11:25am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 503 |
The TD5 and Puma dash fuse boxes use 10-fuse (20-way) Lear (Grote and Hartmann) fuse blocks.
As well as locking tangs on the terminals - Click image to enlarge They have a secondary locking bar, which must be removed before you can release the terminals - Click image to enlarge If you need replacement terminals, I have some compatible Grote and Hartmann terminals, detailed here - https://www.defender2.net/forum/post145671.html#145671 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
6th Oct 2024 4:38pm |
There is the perfect solution from Paul. KEEP CALM AND Drill ON
6th Oct 2024 4:41pm |
Guinness Member Since: 04 Mar 2021 Location: Scotland Posts: 57 |
Thank you very much, ill have a look at this over the weekend!
7th Oct 2024 12:43pm |
