![]() | Home > Puma (Tdci) > Key fob replacement |
Mike2a Member Since: 20 May 2024 Location: Devon Posts: 8 ![]() ![]() ![]() |
Hi all,
I've been looking at key replacement for my 110 as I only ever had one set of keys with it, and came across this. https://www.prestigecarpartsuk.com/product...rrency=GBP It's on the same frequency as my lucas fob could this be coded? Thanks Mike |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2161 ![]() ![]() |
That’s the fob for the later ALM unit serial numbers DHxxxxxx for the 2013-2016 Puma defenders. If you
Currently have a Lucas fob then you will have a ALM CHxxxx or 10AS unit and the fobs you highlighted in the link won’t work. However for ones that will work see below If you are after a new key, or fob , or key and fob, or key and fob combined then options available from remotekey and integrated316. https://www.remotekey.co.uk/category/land-rover/defender/ https://www.integrated316.com/store/p/defender-all-in-one-key |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
Worth checking this thread https://www.defender2.net/forum/topic29683.html
I also converted to that solution and I am quite happy with it... ![]() |
