Home > Puma (Tdci) > Key fob replacement
Mike2a
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Key fob replacement
Hi all,
I've been looking at key replacement for my 110 as I only ever had one set of keys with it, and came across this.
https://www.prestigecarpartsuk.com/product...rrency=GBP
It's on the same frequency as my lucas fob could this be coded?
Thanks Mike
Post #1047720 5th Oct 2024 9:10am
Ianh
That’s the fob for the later ALM unit serial numbers DHxxxxxx for the 2013-2016 Puma defenders. If you
Currently have a Lucas fob then you will have a ALM CHxxxx or 10AS unit and the fobs you highlighted in the link won’t work. However for ones that will work see below
If you are after a new key, or fob , or key and fob, or key and fob combined then options available from remotekey and integrated316.
https://www.remotekey.co.uk/category/land-rover/defender/
https://www.integrated316.com/store/p/defender-all-in-one-key
Post #1047727 5th Oct 2024 10:51am
Mike2a
Thanks for clarifying that. Mine is a 13 plate but I guess in good land rover fashion they used what they had until it ran out.
I was hoping to be able to do a folding key with it but I don't think that will be an off the shelf set up.
Will just stick with standard
Post #1047885 6th Oct 2024 2:43pm
hornet
Worth checking this thread https://www.defender2.net/forum/topic29683.html
I also converted to that solution and I am quite happy with it...
Post #1048131 9th Oct 2024 1:07pm
