![]() | Home > Td5 > Dual Mass or Single Mass flywheel? |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 565 ![]() ![]() ![]() |
I've fitted a few flywheels to various peoples Td5's over the years,
Britpart SMF - Was absolute awful made the layshaft bearings rattle - removed LOF SMF feels very similar to standard no issues and no extra noises. I have a standard Valeo and LUK flywheel in my 90 which is tuned and I tow quite alot, currently on 140,000miles on this clutch with no issues. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 140 ![]() ![]() |
I think I'm going for Valeo DMF and LOF Powerspec, thanks for all the replies, it really helps. ![]() |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 340 ![]() ![]() ![]() |
I'm nearly 2 years into my LOF SMF with road spec clutch and couldn't be happier. My Td5 has a fairly light remap and we tow from time to time. My experience is the SMF made the 110 much nicer to drive, I have also fitted the LOF clutch spring and Power Slave, now the clutch is as light as it is on my Mazda which is a joy to drive.
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 430 ![]() ![]() ![]() |
I was in a simular position with a decent remap from Gareth at Empire and immediately the clutch slipped. I went for a LOF extreme spec and their SMF and i havn't had any issues with Noise, vibration, rattle, clutch slip or any of the aforementioned issues.
not saying anyone is incorrect and not saying that they are perfect etc but its always interesting to get a balance of feedback and so far (15k miles) i have had absolutely no issues whatsoever. I tow (sometimes heavy) and my 130 weights just under 3T although i do treat it nicely, it does get the occasional bit of heavy right foot. Defender 130 HCPU TD5 Series 2a 300tdi L663 5.0 V8 |
Hi, As some feedback, having reverted back to the original map, the clutch stopped slipping, so i think that rules out fuel leaking into the clutch, but thanks for suggestion. Cheers. Defender 90 TD5 2004 |
Hey. I flipped a coin and decided on Powerspec LOF clutch and Valeo DMF. Found the complete kit with Winchester Gears. However, my order was cancelled / refunded because some or part of it was out of stock and was told to maybe contact LOF direct, which i thought was a bit off / odd!? I couldn't see the Valeo DMF on the LOF site, otherwise I would have ordered all of it directly with them. Ideally, I wanted to source the clutch and flywheel from the same source. Now ordered elsewhere. Cheers. Defender 90 TD5 2004 |
Hey everyone, just wanted to provide feedback on this. I went for LOF Powerspec clutch with a Valeo DMF and I'm glad i did. It now easily copes with the stage 2 ish tune / map + uprated intercooler etc. Everything seems well balanced, truck has tremendous pull and seems smoother and more 'driveable' all round. The clutch pedal feels the same as before (in terms of amount of pressure needed to apply). The LOF clutch assist spring really is a good bit of kit and well worth the money in my opinion. For reference, I didn't change either the master or slave cylinder. Just need to tweak the tune / map a bit to get the smoke level down a little (happy to sacrifice some of the new found power / torque). Cheers. Defender 90 TD5 2004 |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3396 ![]() ![]() |
Just to add in to the debate.
I've had a LOF solid flywheel clutch (Powerspec) fitted to my TD5 and it doesn't feel any different to the previous DMF set up. No extra vibration or heavy pedal (I haven't fitted the clutch pedal spring yet). ![]() |
B1_D130 Member Since: 15 May 2022 Location: Scotland Posts: 21 ![]() ![]() ![]() |
I realise you have already sorted you clutch, but just to add my tuppence worth to the conversation.
I too have just had the LOF Powerspec SMF clutch kit fitted. Very happy with it and no noticeable difference in gearbox chatter or noise. The old clutch was just over 100k miles when it went. The pedal was much heavier with the new clutch fitted, but the powerspring makes it much better. Total PIA to fit though. Luke at LOF has been very helpful and knowledgeable and the truck is running great. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4260 ![]() ![]() ![]() |
I saw something on social media (I know, I know
