Home > Puma (Tdci) > Bonnet lettering
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Bonnet lettering
Hi all,
I’m after new Land Rover letters for the bonnet which is being repainted soon and guessing the current ones will break or be no use when they come off for the work to be done.
Rimmerbros want £120 which works out at £13 a letter! Really!!!!!!!??!!
Can anyone recommend another supplier?
Thank you!
Post #1046750 25th Sep 2024 12:42pm
Stacey007
If your current bonnet is badge-less with no sign of where they were, this will be fine.
Its very slightly smaller than the OEMy, but only noticeable if you put it over an existing badge, I know as I have it Smile
https://www.aliexpress.com/item/1005005302...ry_from%3A
Post #1046760 25th Sep 2024 1:24pm
Martin
Site Admin
They look more like the L663 style lettering.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1046762 25th Sep 2024 1:42pm
Stacey007
I may have posted the incorrect link
they have hundreds...
https://www.aliexpress.com/item/1005004149...ry_from%3A
Have a search, if you want to save some money Smile Thumbs Up
Post #1046763 25th Sep 2024 1:44pm
LR Nuts
There are two import things to make sure it's going to look right at the finish
1/ you must use the correct template that holds the letters in the carrier. as this will follow any curve of the bonnet.
2/ you can only apply that template to the correct bonnet
Nothing is more annoying than lettering that is misaligned .
Good Luck
Post #1046767 25th Sep 2024 2:09pm
https://manorautomotive.co.uk/collections/all?page=3 WeWillWin🇬🇧🇺🇸
Post #1046823 25th Sep 2024 10:49pm
