![]() | Home > Puma (Tdci) > Bonnet lettering |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3806 ![]() ![]() |
If your current bonnet is badge-less with no sign of where they were, this will be fine.
Its very slightly smaller than the OEMy, but only noticeable if you put it over an existing badge, I know as I have it ![]() https://www.aliexpress.com/item/1005005302...ry_from%3A |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6643 ![]() ![]() ![]() |
They look more like the L663 style lettering.
I may have posted the incorrect link
they have hundreds... https://www.aliexpress.com/item/1005004149...ry_from%3A Have a search, if you want to save some money ![]() ![]() |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1230 ![]() ![]() |
There are two import things to make sure it's going to look right at the finish
1/ you must use the correct template that holds the letters in the carrier. as this will follow any curve of the bonnet. 2/ you can only apply that template to the correct bonnet Nothing is more annoying than lettering that is misaligned . Good Luck |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
https://manorautomotive.co.uk/collections/all?page=3 TheThunder Rolls🇬🇧🇺🇸
