Home > Td5 > COC data Defender 90 Td5 |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 202 |
Hello,
I can't help with much of your query but there should be a small square sticker on your bulkhead (on my right hand drive, Td5, 110) behind the brake servo. This figure (1.93) is the official emissions code from Land Rover. Click image to enlarge I've no idea what it refers to but hopefully it helps.... 👍👍 Cheers, Dave. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
19th Sep 2024 1:53pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
You might have already found this thread, have you tried JLR direct?
https://www.defender2.net/forum/post801384.html There is a section on CoC on the LR website https://www.landrover.co.uk/ownership/contact-us/faq.html And their contact methods here - https://www.landrover.co.uk/contact-us.html |
19th Sep 2024 1:54pm |
RobertJ Member Since: 18 Mar 2015 Location: Italy Posts: 16 |
Thanks I saw that indeed. So you have also not code on the vin plate above the vin number? It's strange that is is empty. On my puma there is a code stamped. [2015] Land Rover Defender 2.2 TD SW 110 X-Tech [1986] Land Rover 110 2.5 N/A Soft Top |
19th Sep 2024 2:04pm |
I've done all of that already, my only bet is to get some of the missing details from someone unfortunately. [2015] Land Rover Defender 2.2 TD SW 110 X-Tech [1986] Land Rover 110 2.5 N/A Soft Top |
19th Sep 2024 2:05pm |
