![]() | Home > Td5 > COC data Defender 90 Td5 |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 206 ![]() ![]() ![]() |
Hello,
I can't help with much of your query but there should be a small square sticker on your bulkhead (on my right hand drive, Td5, 110) behind the brake servo. This figure (1.93) is the official emissions code from Land Rover. ![]() Click image to enlarge I've no idea what it refers to but hopefully it helps.... 👍👍 Cheers, Dave. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 340 ![]() ![]() ![]() |
You might have already found this thread, have you tried JLR direct?
https://www.defender2.net/forum/post801384.html There is a section on CoC on the LR website https://www.landrover.co.uk/ownership/contact-us/faq.html And their contact methods here - https://www.landrover.co.uk/contact-us.html |
RobertJ Member Since: 18 Mar 2015 Location: Italy Posts: 16 ![]() ![]() ![]() |
Thanks I saw that indeed. So you have also not code on the vin plate above the vin number? It's strange that is is empty. On my puma there is a code stamped. [2015] Land Rover Defender 2.2 TD SW 110 X-Tech [1986] Land Rover 110 2.5 N/A Soft Top |
I've done all of that already, my only bet is to get some of the missing details from someone unfortunately. [2015] Land Rover Defender 2.2 TD SW 110 X-Tech [1986] Land Rover 110 2.5 N/A Soft Top |
