Home > Td5 > TD5 remap |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 700 |
It should smoke a bit, nature of tuning diesels. Also depends what was changed and why. More fuel (at least to some extent) will help off boost performance, which might be desirable, but will generate boost. And using a stock turbo you will have limitations of the stock boost threshold. |
19th Sep 2024 12:26pm |
Ultimately it really comes down to what you want to achieve vs what you want to spend. I know there is talk a few posts back about 300hp, but the reality is, this is exceedingly rare and how reliable is up for debate, due to such a small sample size of people making this power. However, the motor industry does show how these changes have happened too. Just look at the new Defender, 240bhp standard with warranty and meeting emissions from a 2.0 litre diesel. Unheard of power levels years ago. With the Td5, the stock air intake might not be the best for max power, but it is good for general use and off roading. So you may want to weigh up overall priorities. Likewise, free flowing exhaust can be an important part of an entire tuning package. But can be costly and often loud, depending on how you spec/build it. A good intercooler upgrade and a rolling road remap by someone who knows what they are doing should in all likelihood make it drive very well. Going much beyond this and you may want to start to look at the cost of doing an engine conversion instead. A 300hp Td5 is likely more expensive than a 300hp M57 or Chevy LS conversion. |
19th Sep 2024 12:32pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2207 |
M57, stage one 250bhp, standard turbo, 2.5" exhaust, no smoke. 😉 Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
19th Sep 2024 1:53pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17285 |
Surely not, although many do. Smoke indicates that more fuel is being injected than can be fully burned with the available oxygen, and that extra fuel is not generating power, it is just being wasted and only partially burned. A good remap will be clean and avoid exceeding the maximum fuel load for the available oxygen. My BAS map doesn't smoke, and even the relatively unsophisticated "tuning box" I have on my Disco2 doesn't smoke. Just as with a steam railway locomotive, with a diesel engine all that smoke indicates is that fuel is being wasted. |
19th Sep 2024 3:50pm |
Yes the M57 can make good power and be fairly clean. A little haze, not completely smoke free. Suspect this one is running a similar setup to yours. |
19th Sep 2024 3:56pm |
tbh I don't really believe yours makes no smoke at all. Even 100% standard and brand new both the Td5 and M57 will make a bit of smoke under full load at wide open throttle. --- Edit to add: you might not easily be able to see the smoke from the drivers seat while concentrating on driving, but that doesn't mean there isn't any smoke. And it depends how something mapped and its intended use. Smoke may well be unburnt fuel, but that doesn't mean you aren't still making gains. Hence why any professional competition where diesels are used such as tractor pulling or diesel drag racing, they always smoke...... To a certain point, more smoke will still give you more fuel burnt and thus more power, you just have more wastage too. Obviously for road use you want to keep the smoke levels down, but it doesn't mean you get the most power with zero smoke. |
19th Sep 2024 4:01pm |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 128 |
Hi All.
New uprated Intercooler fitted, (Darkside). Bit of a strange one feedback wise. Initially, I could sense the truck felt smoother and seemed less smokey (a bit more poke and less smoke), which was what i was after. However, when the engine was fully warm, the response / power seemed to drop off. I'm not sure if it was increased turbo lag or something, or I need to check the hoses and clips again - maybe small leak. It felt like she didn't want to rev freely. Was wondering if the boost needs upping because of the new intercooler? Will check the basics first, but was unsure why things were better when cold, rather than warmed up? Unfortunately, I don't have a boost gauge or Nanocom, but I do have the Empire Just Map It device, don't know if it shows boost pressure anywhere, at least I couldn't immediately see it on the parameters? BTW, also have performance air filter fitted and i think that made a small positive difference on it's own (fitted and tested before intercooler). Thanks for any suggestions / wisdom. Cheers. |
25th Sep 2024 11:40am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2140 |
Hey,
So with the just map it, you should be able to read boost pressure under one of the live parameters. Will probably read in bar, I havnt got my laptop with me so can't check this second. A boost leak would mean more smoke really. As you have the just map it you can read and clear fault codes so wind the boost up to 1.2bar or 18psi. Instagram @defender_ventures Empire Tuning - Agent |
25th Sep 2024 11:46am |
Thanks Bankz.
I took it for another drive and everything seemed fine with improved 'driveability' and 'smoothness' I'd say (I haven't changed / adjusted anything since this morning)! I will clear the diagnostic info / errors and go for a spin and get clean info. Regarding the Just Map It, I still can't find Boost pressure, I can only find ambient air pressures and inlet manifold pressures, but I thought that was different to boost pressure? Possibly, boost pressure is the difference between ambient and intake manifold pressures? Cheers. |
25th Sep 2024 4:01pm |
