![]() | Home > General & Technical (L663) > Land Rover coolant |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2951 ![]() ![]() |
lt's true. Nobody knows!!
Well, l diluted it 50/50 as all the other OAT antifreeze l've got says dilute 50/50 unless you are in the Arctic and it's -50 outside. lt's only a 0.3 litre top up it needed anyway so it won't make any difference to the system's 10 litre likely capacity. But someone, somewhere must know. l messaged two sellers on Ebay but neither responded. |
The eternal enigma.
Is the Land Rover coolant used as is, or should it be diluted before use. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2138 ![]() ![]() |
If itโs the same stuff they sell for the Puma then it will be concentrated and should be diluted 50% with deionised water
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 53 ![]() ![]() |
![]() Click image to enlarge yes, I also searched, that's why I bought this product, which meets the prescribed standard STJLR.651.5003 and where it's more clear - you can buy both concentrate and already mixed mixture |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 103 ![]() ![]() |
On page 461 of my Handbook it says that the coolant is a mixture of 50% water and 50% antifreeze meeting ST JLR 651.5003. So I think the requirement is to dilute it the antifreeze supplied by JLR with water.
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 112 ![]() ![]() |
This is what I bought from the dealer. Supposed to dilute it 50/50. Luckily I haven't had to use it yet.
![]() Click image to enlarge ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar) ๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
Thank you for the replies. l've just had a response from one of the Land Rover dealers who confirmed that the antifreeze should be diluted 50/50 with water.
Just make sure you use deionised water, itโs cheap .
