Home > General & Technical (L663) > Land Rover coolant
lightning
Land Rover coolant
Can anyone tell me if this product should be diluted or is it used straight from the container. Nobody seems to know.
Even the dealer couldn't tell me. lt says nothing on the container.
Post #1045812 14th Sep 2024 4:12pm
lightning
lt's true. Nobody knows!!
Well, l diluted it 50/50 as all the other OAT antifreeze l've got says dilute 50/50 unless you are in the Arctic and it's -50 outside.
lt's only a 0.3 litre top up it needed anyway so it won't make any difference to the system's 10 litre likely capacity.
But someone, somewhere must know. l messaged two sellers on Ebay but neither responded.
Post #1045828 14th Sep 2024 9:15pm
lightning
The eternal enigma.
Is the Land Rover coolant used as is, or should it be diluted before use.
Post #1045888 15th Sep 2024 7:39pm
Ianh
If itโ€™s the same stuff they sell for the Puma then it will be concentrated and should be diluted 50% with deionised water
Post #1045900 15th Sep 2024 10:16pm
sasa
Czech Republic
yes, I also searched, that's why I bought this product, which meets the prescribed standard STJLR.651.5003 and where it's more clear - you can buy both concentrate and already mixed mixture
Post #1045905 16th Sep 2024 6:05am
martinf
On page 461 of my Handbook it says that the coolant is a mixture of 50% water and 50% antifreeze meeting ST JLR 651.5003. So I think the requirement is to dilute it the antifreeze supplied by JLR with water.
Post #1045911 16th Sep 2024 7:17am
CincyRovers1
United States
This is what I bought from the dealer. Supposed to dilute it 50/50. Luckily I haven't had to use it yet.
 ๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐ƒ๐ž๐Ÿ๐ž๐ง๐๐ž๐ซ ๐Ÿ๐Ÿ๐ŸŽ ๐’ ๐๐Ÿ‘๐ŸŽ๐ŸŽ (Pangea Green over Acorn/Lunar)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ‘ ๐๐จ๐ซ๐ฌ๐œ๐ก๐ž ๐Œ๐š๐œ๐š๐ง ๐’ (Dolomite Silver over Black/Bordeaux Red)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ• ๐ƒ๐ข๐ฌ๐œ๐จ๐ฏ๐ž๐ซ๐ฒ ๐‡๐’๐„ ๐‹๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐’๐ข๐Ÿ” (Aintree Green over Vintage Tan/Ebony) - Gone
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐‹๐‘๐Ÿ’ ๐‡๐’๐„ ๐Ÿ“.๐ŸŽ (Ipanema Sand over Almond/Arabica) - Gone
Post #1046014 17th Sep 2024 12:55pm
lightning
Thank you for the replies. l've just had a response from one of the Land Rover dealers who confirmed that the antifreeze should be diluted 50/50 with water.
Post #1046061 17th Sep 2024 10:16pm
Ianh
Just make sure you use deionised water, itโ€™s cheap .
Post #1046065 18th Sep 2024 12:44am
