![]() | Home > Puma (Tdci) > Injector Replacement |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 172 ![]() ![]() ![]() |
Clean and/or recut your injector seats as required at the same time. Don’t change the VCV unless there is a problem.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
Do not forget the copper shims, new bolts etc Puma 110" SW
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 856 ![]() ![]() ![]() |
If the VCV is working correctly then leave well alone.
Jim |
