Home > Puma (Tdci) > Injector Replacement
chrisc2306
Scotland 2011 Defender 90 Puma 2.4 CSW Zambezi Silver
Hi everyone I've just ordered 4 new injectors for my 2010 puma, is there anything I need to know about changing them over or is there anything that you'd recommend replacing at the same time, I'm planning on changing the vcv valve when I'm doing it too, is there anything else? I have a nanocom is the coding process straightforward?
Post #1045664 12th Sep 2024 6:53pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Clean and/or recut your injector seats as required at the same time. Don’t change the VCV unless there is a problem.
Post #1045697 13th Sep 2024 5:58am
MK
Do not forget the copper shims, new bolts etc Puma 110" SW
Post #1045728 13th Sep 2024 11:20am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
If the VCV is working correctly then leave well alone.
Jim
Post #1045767 14th Sep 2024 1:10am
