![]() | Home > Series Land Rovers > Series 3 Axel in Series 1 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17683 ![]() ![]() ![]() |
The track is about 1" wider. They will fit (but not in an 80") but are not ideal, and they're also not any stronger. A lot of folk (myself included) have fitted a later rear axle to a post-'54 Series One in order to run fully-floating hubs with later half shafts (S1 fully-floating half shafts are unobtainable as far as I know).
Bearing in mind we used to sling Rover V8 engines in Series Ones without breaking the driveline I have to wonder what power increase you're planning. A.SIII gearbox is not as strong as a pre-synchro SII box by the way. |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1392 ![]() ![]() ![]() |
I fitted spacers to my series one rear axle made from turned down flanges, so that I was then able to fit S2/3 half shafts thereby converting to fully floating axles. I am not sure if the half shafts are any stronger, but they are easier to replace than hard to obtain series one types. I have known people shorten S2/3 shafts which also works, but could lead to splines failing. Euro-Leafing to infinity and beyond.....
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
A German member of the Series One Club, sadly no longer with us had a number of original spec fully floating half shafts made for the Series One. I understand the Club bought all the stock, there may still be some available for sale if you contact the Club.
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 765 ![]() |
I run a series 11 axle on the rear of my 88” series 1 with no problems.(still have series 1 narrower axle on the front)
As said above it’s easier to replace half shafts and replace bearings. |
