Home > Series Land Rovers > Series 3 Axel in Series 1
Stacey007
Hello
Will a series 3 axel (front / rear) fit a Series one. I seem to think they are too wide?
Or what options to upgrade a Series 1 Axel to take more power?
Post #1045303 9th Sep 2024 3:11pm
The track is about 1" wider. They will fit (but not in an 80") but are not ideal, and they're also not any stronger. A lot of folk (myself included) have fitted a later rear axle to a post-'54 Series One in order to run fully-floating hubs with later half shafts (S1 fully-floating half shafts are unobtainable as far as I know).
Bearing in mind we used to sling Rover V8 engines in Series Ones without breaking the driveline I have to wonder what power increase you're planning.
A.SIII gearbox is not as strong as a pre-synchro SII box by the way.
Post #1045330 9th Sep 2024 6:41pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I fitted spacers to my series one rear axle made from turned down flanges, so that I was then able to fit S2/3 half shafts thereby converting to fully floating axles. I am not sure if the half shafts are any stronger, but they are easier to replace than hard to obtain series one types. I have known people shorten S2/3 shafts which also works, but could lead to splines failing. Euro-Leafing to infinity and beyond.....
Post #1045337 9th Sep 2024 7:14pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
A German member of the Series One Club, sadly no longer with us had a number of original spec fully floating half shafts made for the Series One. I understand the Club bought all the stock, there may still be some available for sale if you contact the Club.
Post #1045453 10th Sep 2024 6:10pm
gcc130
I run a series 11 axle on the rear of my 88” series 1 with no problems.(still have series 1 narrower axle on the front)
As said above it’s easier to replace half shafts and replace bearings.
Post #1045454 10th Sep 2024 6:18pm
