![]() | Home > Technical > Dim Dip |
Blackwolf - I agree with all you say above.
Never liked dim dips, they draw the current, and reduce bulb life...where the benefit in that? It's becoming a battle for brighter lights. Having hit a deer last year, I have been improving my lights (Philips Extrem bulbs) to give me better vis on dip beam (and may fit some driving lights before next winter on the Defender (I travel quite a bit in North Scotland) However, there seems to be an increase in illegal and inconsiderate use of lights (Fogs, for instance should only legally be used when visibility is reduced to 100 metres or below...and then WITHOUT the dip beam ...the idea being that the fog lights stop light reflection in falling snow or thick fog... but no-one seems to actually know that!) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
mfspannerman Member Since: 18 Nov 2012 Location: Suffolk Posts: 36 ![]() ![]() ![]() |
What is the easiest way to dissable the dim dip on my land rover as i am getting fed up of keep changing head light bulds!
![]() Thanks Make tracks and get moving!! PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6139 ![]() ![]() ![]() |
Td5 is the same ^^^^
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
That's interesting. I didn't realise this feature was ever fitted to the Puma. Maybe it was dropped early on as I'm sure that mine doesn't have it. Pete |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17614 ![]() ![]() ![]() |
It was fitted to the "more commercial" versions at least in the early days. You either had the headlamp adjuster (on "non-commercials" such as the SW) or dim dip (on "commercials" such as the DC). My '07 DC had dim dip. Not sure what happened later on when they all became Euro Class N rated. |
thank you all for your help that worked and now dim dip doesn't!
![]() PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT! |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 ![]() ![]() ![]() |
Any chance someone could post a photo showing where this resistor lives, I've looked on mine (TD5) and I cant see it ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
It's in a place where it cannot be photographed, unfortunately. It is somewhere between the radio aerial and the plastic cover on the o/s from wing upper surface, inside the wing. A torch and mirror may allow you to see it.
Assuming, of course, that you have one and it is in the same place! |
Thank you mr wolf, I will look tomorrow
Sorry (as always) for my stupidity but can I be certain that with a "European" Puma SW (2011) I don't have one of these things? Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
^^^Same question here. Would a 2009 model (produced August 2008) left hand drive non-UK Station Wagon have such a resistor installed? In any case I never had that dim dip function, and I also have the electric headlamp adjuster on mine.
Asking this, because shortly I will have my lighting loom adjusted to channel the headlight power direct from battery to lamps without passing in full force via the light switch. And in a different thread here some remarks were made that if there is a dim dip resistor, it might cause some headaches to this adjusted loom installation working properly. So if anybody can confirm would be much appreciated. Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5815 ![]() ![]() |
The easiest way to tell if you have dim dip is to have engine running, put side lights on. If you have NO illumination in headlights, you don't have dim dip. If you have a dull glow from the headlight you HAVE dim dip.
My 10 reg double cab has dim dip. But not really concerned as I never use side lights. Lights either on or off. Andy |
Tks Andy, as already said I don't have dim dip. Just wondering if they still installed that resistor in the loom somewhere, just like Defenders often have wiring installed for certain factory options which were not ordered and not installed. (like for loudspeakers and radios, etc....)
the resister is plugged in to the loom not part of the loom .so guess it would not be fitted if not used
