Home > Maintenance & Modifications > Tyre Size Question
Balfour
Tyre Size Question
Hi all,
Have just rejoined the forum after a five year Landy-free period (it was hell & heaven!) and its nice to see the community going strong still.
I've just picked up a TD5 90 and am going to fit 1" lowering springs. The current wheels and tyres are coming off and I'm putting on 16 x 6.5" wolf steels.
I previously lowered a 90XS I had but I left the sawtooth wheels that it came with originally on and I can't remember what tyres were on it.
My initial thought was to fit 235/85 tyres but I'm not sure if this will look right... Has anyone else lowered theirs by 1" and if so, what tyre size would you recommend?
Post #1044009 27th Aug 2024 2:50pm
jst
The saw tooth most likely had 235.85s on them. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1044011 27th Aug 2024 3:54pm
revd
235/85 are the widest recommended tyre for 6.5" rims
Post #1044015 27th Aug 2024 4:22pm
Chicken Drumstick
Re: Tyre Size Question
Balfour wrote:
Hi all,
What are you trying to achieve?
I assume by lowering you have no intention to use the vehicle for its core purpose off road?
A smaller tyre might suit better. A smaller sidewall will have less tyre roll in the corners. Although a narrow tyre is likely to “handle” and drive better with better steering feel and better mpg.
If you want max lateral grip on dry tarmac a fat tyre should work better.
Lots and lots of potential sizes. You may want to hold off on the rims though. A 6.5” width may limit options.
Post #1044071 28th Aug 2024 7:34am
Chicken Drumstick
Not exactly. You can certainly get wider such as a 255/85.
Post #1044072 28th Aug 2024 7:35am
revd
Land Rover engineer of long-standing I spoke to last week said go 7" rim if you want to fit wider than 235. He signed off the Defender tyres back in the day after extensive testing on Michelin's track at Clermont Ferrand
Post #1044073 28th Aug 2024 7:48am
255/85 is okay, (what I have on boosts) but they are the limit really. WeWillWin🇬🇧🇺🇸
Post #1044078 28th Aug 2024 9:21am
Many people have run 285/75 MTs on Boosts without problems (at least, the only problem is finding someone prepared to take on the struggle of fitting them).
Post #1044083 28th Aug 2024 9:59am
rallysteve
Generally it is the tyre manufacturer who defines the necessary rim width for their tyres rather than the vehicle manufacturer.
Vehicle manufacturer's interest is normally concerned with clearances (not an issue for Defenders as you can adjust the steering lock stops) and economy figures/NVH (definitely not a concern for a Defender Rolling with laughter ) 02' 110 TD5 Double Cab Rebuild Thread
Post #1044091 28th Aug 2024 10:49am
There was a struggle with the 255’s so that is a very good point. WeWillWin🇬🇧🇺🇸
Post #1044102 28th Aug 2024 12:51pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
ETRTO
If you aren't sure about compatibility of rim/tyre size- have a look online for the ETRTO (European Tyre and Rim technical Organisation) standards and guidance for rim and tyre fitting compatibility.
Chris
Post #1044103 28th Aug 2024 12:54pm
revd
I think you sell LR short, extensive testing goes well beyond the basic parameters you listed, which could well be arrived at by testing on UK roads. Part of the reason there are so many badly modified Defenders out and about is because so many folk jump to the conclusion, 'it's only a Defender - anything goes'. In reality the vehicle underwent constant development throughout its life and with the huge availability of aftermarket parts it is easy to undo the best efforts of the engineers who designed and built them.
Post #1044106 28th Aug 2024 1:02pm
There certainly is a lot of aftermarket parts that are a downgrade that’s for sure, and can cause more problems than they are worth.
I’m surprised LR didn’t offer better spec tyres of different types from the factory though, but I expect that’s based on tyring to keep MPG figures upwards for certification etc.
I really don’t miss road bias General Grabber TR’s that’s for sure, very skittish and prone to damage as well. WeWillWin🇬🇧🇺🇸
Post #1044108 28th Aug 2024 1:07pm
Chicken Drumstick
Clearly he is wrong and doesn't know jack s*** then.... Laughing Either that or companies like BFG have no idea.... Whistle
Rim width is also dependant on sidewall height, not just section width.
Post #1044119 28th Aug 2024 2:35pm
revd
Difference between what fits and what works. Rather than choose tyres solely based on the fitment chart of the tyre manufacturer I would go with the advice of a guy who has lived and breathed LR all his working life.
Post #1044126 28th Aug 2024 3:37pm
