Home > Maintenance & Modifications > Tyre Size Question |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7857 |
The saw tooth most likely had 235.85s on them. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Aug 2024 3:54pm |
revd Member Since: 20 Apr 2024 Location: England Posts: 62 |
235/85 are the widest recommended tyre for 6.5" rims
27th Aug 2024 4:22pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 672 |
What are you trying to achieve? I assume by lowering you have no intention to use the vehicle for its core purpose off road? A smaller tyre might suit better. A smaller sidewall will have less tyre roll in the corners. Although a narrow tyre is likely to “handle” and drive better with better steering feel and better mpg. If you want max lateral grip on dry tarmac a fat tyre should work better. Lots and lots of potential sizes. You may want to hold off on the rims though. A 6.5” width may limit options. |
28th Aug 2024 7:34am |
Not exactly. You can certainly get wider such as a 255/85. |
28th Aug 2024 7:35am |
Land Rover engineer of long-standing I spoke to last week said go 7" rim if you want to fit wider than 235. He signed off the Defender tyres back in the day after extensive testing on Michelin's track at Clermont Ferrand
28th Aug 2024 7:48am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20096 |
255/85 is okay, (what I have on boosts) but they are the limit really. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
28th Aug 2024 9:21am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17202 |
Many people have run 285/75 MTs on Boosts without problems (at least, the only problem is finding someone prepared to take on the struggle of fitting them).
28th Aug 2024 9:59am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2221 |
Generally it is the tyre manufacturer who defines the necessary rim width for their tyres rather than the vehicle manufacturer.
Vehicle manufacturer's interest is normally concerned with clearances (not an issue for Defenders as you can adjust the steering lock stops) and economy figures/NVH (definitely not a concern for a Defender ) 02' 110 TD5 Double Cab Rebuild Thread |
28th Aug 2024 10:49am |
There was a struggle with the 255’s so that is a very good point. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
28th Aug 2024 12:51pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 784 |
If you aren't sure about compatibility of rim/tyre size- have a look online for the ETRTO (European Tyre and Rim technical Organisation) standards and guidance for rim and tyre fitting compatibility.
Chris |
28th Aug 2024 12:54pm |
I think you sell LR short, extensive testing goes well beyond the basic parameters you listed, which could well be arrived at by testing on UK roads. Part of the reason there are so many badly modified Defenders out and about is because so many folk jump to the conclusion, 'it's only a Defender - anything goes'. In reality the vehicle underwent constant development throughout its life and with the huge availability of aftermarket parts it is easy to undo the best efforts of the engineers who designed and built them. |
28th Aug 2024 1:02pm |
There certainly is a lot of aftermarket parts that are a downgrade that’s for sure, and can cause more problems than they are worth.
I’m surprised LR didn’t offer better spec tyres of different types from the factory though, but I expect that’s based on tyring to keep MPG figures upwards for certification etc. I really don’t miss road bias General Grabber TR’s that’s for sure, very skittish and prone to damage as well. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
28th Aug 2024 1:07pm |
Clearly he is wrong and doesn't know jack s*** then.... Either that or companies like BFG have no idea.... Click image to enlarge Rim width is also dependant on sidewall height, not just section width. |
28th Aug 2024 2:35pm |
Difference between what fits and what works. Rather than choose tyres solely based on the fitment chart of the tyre manufacturer I would go with the advice of a guy who has lived and breathed LR all his working life.
28th Aug 2024 3:37pm |
