Home > Puma (Tdci) > 2.4 Puma Engine into 2.2 Puma
nickhodgson
Hi
I have a broken engine in a 2.2 Puma Defender. I also have a good 2.4 Puma engine. Would like to put the 2.4 engine in the 2.2 Defender.
Currently have the following:
2.4 Puma Engine including loom
2.4 Puma chassis harness including 2.4 fuel lines and tank sender unit
2.4 Puma main harness
A green alarm box
A 2.4 Puma Dash Cluster and a 2.2 Puma Dash Cluster
A 2.4 Puma ECU
Many other necessary 2.4 bits
What is the chance of this engine running with all these 2.4 Puma bits? Or what do I need to do to get it to run? Its really the electrics / alarm / syncing issues that I think may cause problems.
Where is the chassis number stored? Instrument Cluster or ECU or both?
I have another working 2.4 Puma to make comparisons if necessary.
Thanks
Nick 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #1043880 26th Aug 2024 8:23am
MK
IIRC the vin is originaly written on the ECU and then it is registered into a EEPROM chip into the IPAC. I believe it is possible to erase/change the eeprom. I am sure somebody will come with a more precise answer. Finally, the known tuners will know the exact answer. Puma 110" SW
Post #1043894 26th Aug 2024 12:09pm
Ianh
The IPAC eeprom would need replacing to change the vin and to change mileage if it needs to be reduced.
So called “ mileage correction “ ( clockers Mad ) companies can do this.
Post #1043906 26th Aug 2024 1:19pm
