Home > Puma (Tdci) > Power loss when driving at constant speed
RichardS
Canada 2009 Defender 110 Puma 2.4 CSW Alaska White
My 2009 2.4TDCI Defender 110 has developed an intermittent snag which I hope someone will be able to help diagnose. When cruising on the motorway at 2000rpm there is the occasional feeling that there is a loss of boost (but with no ugly noises). It has not yet developed further into a permanent loss of power, but I am hoping that with guidance, I may be able to carry out corrective action before further problems.
Can anybody offer suggestions as to what might cause this deficiency?
Thanks
Richard
Post #1043313 20th Aug 2024 3:19pm
jst
Sticky turbo vanes. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1043322 20th Aug 2024 4:14pm
hank
Post #1043326 20th Aug 2024 4:21pm
kmac
VCV - This
Post #1043541 22nd Aug 2024 11:53am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
When you get the power loss does it last a few seconds and then the power comes back? Doe the vehicle ever cut out when coming to a junction and then have to be restarted?
Jim
Post #1043542 22nd Aug 2024 12:05pm
BrickBox
Can someone also link me to a ‘known’ reliable replacement VCV also, please?
I have read the treads, but some of the links no longer exist.
Bell Auto Services site is under maintenance and isn’t showing VCV valves available
This is the only one I’ve come across from a known seller
https://www.pfjones.co.uk/fuel-pumps-and-i...alves.html 2008 2.4 110 Utility Station Wagon XS.
Post #1043546 22nd Aug 2024 1:06pm
jim4244
BrickBox - A lot of folk swear by PF Jones.
As its a Ford engine some also just buy a VCV (Sometimes called a SCV) from a Ford main dealership.
Jim
Post #1043547 22nd Aug 2024 1:11pm
BrickBox
Assuming the one I’ve linked is the correct one then? Smile 2008 2.4 110 Utility Station Wagon XS.
Post #1043549 22nd Aug 2024 1:17pm
PF Jones is where I went and got mine, not had any issue at all, and has been running great.
No learning needed just fit and forget for its life that it works in good order. TheThunder Rolls🇬🇧🇺🇸
Post #1043571 22nd Aug 2024 5:59pm
MK
Genuine ones are made in Hungary. Puma 110" SW
Post #1043641 23rd Aug 2024 12:08pm
hank
See here https://www.defender2.net/forum/topic93101.html > 110 XS Double Cab
Post #1043982 27th Aug 2024 9:46am
hank
Post #1043983 27th Aug 2024 9:47am
jst
jst wrote:
Sticky turbo vanes.
At loss of power does it come back gain on its own or do you have to cycle ignition.
Does the turbo have full range of movement through the actuation arm. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1043991 27th Aug 2024 11:02am
BrickBox
The LR Parts link is no longer available. 2008 2.4 110 Utility Station Wagon XS.
Post #1043994 27th Aug 2024 11:16am
hank
Post #1043997 27th Aug 2024 11:32am
