Home > Td5 > A/C not cooling, what DIY checks to do? |
revd Member Since: 20 Apr 2024 Location: England Posts: 91 |
Call an expert
Not for a Defender, but I had a mobile air-con specialist out to the house, not expensive at £65 for a pressure test and re-gas |
15th Aug 2024 2:37pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 728 |
Most systems need re gassing every 2-3 years as they slowly leak, especially if you don’t run the A/C all the time. A specialist will have the kit which regasses and relubricates the system and checks for significant pressure loss.
Well worth leaving it to the experts. |
15th Aug 2024 3:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20220 |
I think it needs re-gassing as mentioned, it’s a common job that needs doing but not DIY.
Not very expensive, places like Halfords do it. (Doubt it will be more than £80). I’d avoid LR they’ll find a way of making the job £1000. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
15th Aug 2024 6:55pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1576 |
it's a specialist job.
they will pressure test the system. sniff test for leaks? if it holds gas then they can regas and or oil if need and also add a sealant to stop small leaks |
15th Aug 2024 8:55pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2631 |
Is the condenser still intact or have all the fins fallen off like many?
15th Aug 2024 9:55pm |
