Home > My Defender > Neglected for too long
Page 2 of 2 <12
They are excellent for some things thatโ€™s for sure, and easy to disconnect.
When I used the Anderson connectors I used the boots with them as well and 6mm2 cable I believe so there was a tight fit on the cable exits, on the butt joint between the boots I used adhesive electrical tape around that in a neat tight wrap with a tear off tab if needed for disconnection which makes it easier.
And I put on some of the captive Anderson dust caps, so they are there if needed if disconnected.
This is for the 50A red ones, there are much higher rated ones with pull handles etc as well, Iโ€™m unsure if there are boots for them though, I expect there is from the same manufacturer.
Some technical details about them all:
See Here.
Most people on here already know quite a bit about them anyway. Very Happy KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1044107 28th Aug 2024 12:03pm
Stiff1
custom90 wrote:
Stiff1 - Have you considered a Naka DAB Aerial? I think that would look nice on yours. Thumbs Up
I was toying with putting a fin on the back of the roof but the rack doesn't comply... Then neither does it with the roof tent so always on the lookout for a Patriot/ Hannibal type.
Post #1044175 28th Aug 2024 7:52pm
Page 2 of 2 <12
