Home > Td5 > Hazard Switch in a "Newer" Td5 Dash
robpenrose
Does anyone know if you can replace just the bulb in the hazard switch.
Just rung my local dealer and they said you have to buy a whole new switch @ £25!!!
I have pulled it out and you can remove the bulb. Its basically mounted on a little piece of circular black plastic, that you unscre 1/4 turn and it pops out nicely. To put it back in, simply push in and turn.
I find it a bit hard to believe that you cant change the bulb even though you can get it out easily?? It looks like it needs the bulb and plastic screw in bit to come as one that you just screw in to replace.
Anyone changed theirs, or know where i might be able to get the correct bulb from without buying the whole switch?
Rob Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #101634 22nd Nov 2011 1:24pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Sounds just like a dashboard bulb (i.e. the type that goes in the speedo), they are available on ebay but I can't remember off the top of my head what code they are.
Post #101636 22nd Nov 2011 1:30pm
Sounds very similar to the bulbs used in the head unit (radio) of the Disco 2.
Post #101641 22nd Nov 2011 1:50pm
PaulMc
Rob
Some Dealers really are cr@p Mad
The bulb isn't listed separately in Microcat for the 2002> Defender Hazard Warning Switch, however...
... it is listed for the 300TDi Discovery Hazard Warning Switch (which is essentially the same switch, but vertical instead of horizontal)
STC1205 - BULB & HOLDER ASSEMBLY, CLEAR - £3.24 incl. VAT
http://www.rimmerbros.co.uk/Item--i-STC1205
. Paul.
Post #102227 24th Nov 2011 4:48pm
Same switch as used on rover 25 cars too.
Post #102330 24th Nov 2011 9:46pm
robpenrose
F*ck, f*ck, f*ck, i got a new switch from the dealer for the sum of £24 after searching the internet and asking various land rover parts stockists that all said the same thing.
I put it all back together about and hour ago.
Typical..
Hopefully at least somone wont have to pay for the same issue in the future. Thanks to everyone who responded.
If anyone needs a switch, i know have a spare that somone could put a bulb in??? Current:D4 HSE
Gone: BMW Z4MC
Post #102625 26th Nov 2011 12:37pm
PaulMc
Typical..
That's a bummer Sad
Put your spare switch on eBay (it's Free Listing this weekend ), even with a blown bulb, you'll recoup some of your £24
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #102654 26th Nov 2011 3:07pm
