Home > General & Technical (L663) > L663 abrupt reaction when selecting short range!!
ruben
Spain
As I said, I select the low range in my L663 MY 23 and the car seems abrupt and reactive, not when starting off, not when starting the movement, it does that with its usual silence and smoothness, The movement is completely normal in short ones, the abruptness is when selecting them.… I mean when selecting low range from N, there is a kind of jerk in the transmission shaft, as if the car were slowing down while in N, something abrupt and noticeable, in my longed for manual D3 that didn't exist, I only perceived an elegant tinkling in the transfer case, and here it seems to come in with a hammer, should I check this? is it normal? I have less than 10,000 m. Thanks in advance!
Post #1042115 7th Aug 2024 11:27am
ruben
Spain
I answer myself, πŸ™ƒ is it possible that the transfer case needs to be recalibrated?
Post #1042143 7th Aug 2024 7:02pm
ruben
Spain
Is it normal to see the central differential lock acting normally during normal high range driving on streets, highways and roundabouts etc?
Post #1042144 7th Aug 2024 7:04pm
J77
There is a slight jerk when going from high to low range on Defender. 24MY 90 D250 HSE, Tasman Blue
Post #1042145 7th Aug 2024 7:40pm
ruben
Spain
Thanks Moo, that's exactly what I wanted to say, but I used too much paraphernalia! I always think that if I don't overexplain, no one will understand my English.!! 🀭πŸ€ͺ
Post #1042146 7th Aug 2024 7:45pm
Moo
Ukraine
That's Ok, but think J77 contributed more..... Laughing Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1042155 7th Aug 2024 9:14pm
ruben
Spain
Oh my god, I didn't put the remedies for presbyopia and ended up with Moo, I'm so sorry j77, I'm a complete imbecile!! many thanks!! 🫣😏
Post #1042158 7th Aug 2024 9:27pm
Moo
Ukraine
It just confirms you fit well into the mad house. Laughing Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1042159 7th Aug 2024 9:33pm
ruben
Spain
thanks Moo, I always appreciate your characteristic kindness! and even more so in this disgusting world!!πŸ‘πŸΌπŸ‘πŸΌ
Post #1042160 7th Aug 2024 9:40pm
lightning
When in low range if it's possible to select the "ECO" driving program this is quite a lot smoother in response.
Post #1042191 8th Aug 2024 7:00am
ruben
Spain
thanks, i will try it!! πŸ‘πŸΌ
Post #1042196 8th Aug 2024 7:25am
J77
No problem Thumbs Up
Your English is fine, I’m Scottish so we are probably on the same level of ability Laughing 24MY 90 D250 HSE, Tasman Blue
Post #1042238 8th Aug 2024 2:25pm
ruben
Spain
Post #1042247 8th Aug 2024 3:25pm
