Home > Td5 > Crankshaft sensor |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 524 |
Is wading plug in bellhousing?
2nd Aug 2024 8:27pm |
Wag Member Since: 27 Nov 2023 Location: Londonderry Posts: 18 |
will check and get the oil dry ready, you would think someone more use to leafers would have checked this.
2nd Aug 2024 8:53pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5614 |
Yes they are often grubby. Worse if any rear engine oil leaks, or if FPR is leaking.
The wading plug stays fitted on the Td5 but itโs is worth removing every now and then, but there is a small gap by the wading plug between engine and bell housing and this should be clear, and often blocks up. Easily cleared with a cable tie poked through there. |
3rd Aug 2024 4:23am |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 201 |
Hello,
You can test them with a multimeter. I read a post somewhere which told you exactly what you were looking for on a Td5 but I can't find it now. I did find this 'generic' one though... Hope it helps..๐๐ 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
3rd Aug 2024 10:43am |
Doing a chassis change on a neighbours TD5, took wading plug out, 1/2 litre of oil/diesel clutch dust sludge came out, rear rocker seal leak main culprit. |
3rd Aug 2024 11:33am |
Thanks
Rebuilt the fpr about 2 months ago because it was leaking that would explain it. |
3rd Aug 2024 11:46am |
I learnt the hard way of getting what looked like a couple of litres of diesel in my bell housing with a leaking FPR. Didnโt do much for my clutch
Soon learnt to keep the little vent/drain clear. |
3rd Aug 2024 2:03pm |
1.3 on the ohms test didn't go any further , new lucas part now on. Thanks |
3rd Aug 2024 2:25pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5118 |
Wag, yeah, my rev counter was very hit and miss, and the motor seemed to be under powered, at times. Mine was down to the gearbox seal failing. It was all cleaned and all is well, rev counter works, the 5 is a live again. You can get cheap ones, that will start the car, but as soon as you rev it. It will cut the car out and tossed the EM light on. When me and my dad did the fuel pump on mine, we had a bit of a play with a cheap sensor, with the volt meters on both original one and the cheap one. Both registered spot on. So not sure what the story is with the cheap crap. Also they are Rover K series crank sensors too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
25th Aug 2024 5:08pm |
