Home > Puma (Tdci) > 2.2 Engine failure
Pieter Landy
South Africa 2014 Defender 130 Puma 2.2 HCPU Alaska White
2.2 Engine failure
Is it worthwhile to repair broken piston no 3 on 2.2 Puma engine
Post #1041357 30th Jul 2024 11:13am
TexasRover
While you can repair a broken engine, you never know what impact the failure might have had on the engine and unless you go clinical with a full dismantle, cleaning and condition verification of every critical component. This is expensive.
Depending on the value of the car, intended use etc it might be better to install a good used engine, ideally from an decent accident vehicle with a known engine condition. Alternatively you can look at rebuild engines from a reputable maker.
Post #1041362 30th Jul 2024 11:50am
