Home > For Sale & Wanted > SOLD Roamerdrive Overdrive
Rick81
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Galway Green
Roamerdrive DS Overdrive, less than 200 miles before removal due to vehicle mishap (not related to overdrive), latest model will fit Td5 and earlier giving 28% reduction in revs. Comes with everything including all supplied lock ages, bolts etc and spare o rings for selector and bolts. Genuine Timken bearing fitted to nose (again, less the 200 miles), in-crushed crush washer you just need a standard PTO cover gasket and some oil! No longer supplied over here so difficult to find unless you import from Canada (like I did). SOLD
Post #1041168 28th Jul 2024 8:22am
mini Anaconda
Great bit of kit, we have one on our Td5 Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #1041185 28th Jul 2024 3:30pm
Rick81
Not sure why it corrected it to in-crushed, should be un-crushed crush washer! Also obviously has the gaiter and the foam from the original defender cut for the third lever
Post #1041221 28th Jul 2024 9:32pm
