SOLD Roamerdrive Overdrive
Roamerdrive DS Overdrive, less than 200 miles before removal due to vehicle mishap (not related to overdrive), latest model will fit Td5 and earlier giving 28% reduction in revs. Comes with everything including all supplied lock ages, bolts etc and spare o rings for selector and bolts. Genuine Timken bearing fitted to nose (again, less the 200 miles), in-crushed crush washer you just need a standard PTO cover gasket and some oil! No longer supplied over here so difficult to find unless you import from Canada (like I did). SOLD
28th Jul 2024 8:22am
mini Anaconda
Great bit of kit, we have one on our Td5 BORG - Bucks & Oxon 4x4 Response Group
28th Jul 2024 3:30pm
Rick81
Not sure why it corrected it to in-crushed, should be un-crushed crush washer! Also obviously has the gaiter and the foam from the original defender cut for the third lever
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
