Home > Technical > A Land Rover Holiday - clutch issue?
WestCountryPete
We set off for our family holiday into France yesterday. 1am this morning we stopped to pay our toll and….won’t go into any gears! Didn’t even make it to our first night’s accommodation Big Cry
Just to make matters a little worse - no hotels available so we slept in the car at 3am, in an industrial area.
2011 2.4 Utility. So, I’m thinking the clutch has gone? Goes into gear (as far as I can tell) fine without the engine running. Just waiting for a mechanic to open up but not sure Puma’s are their thing.
Post #1041009 26th Jul 2024 7:11am
Bluest
Same thing happened to me last week when we set off for Spain. We didn't even make it as far as the tunnel. From my understanding it is likely to be the master or slave cylinder.
You can find a list of Land Rover specialists in France here, maybe one is near to you. https://www.landmag.fr/les-specialistes-la...-belgique/
Good luck and keep us updated. 2007 110 TDCi Station Wagon XS
Post #1041010 26th Jul 2024 7:20am
WestCountryPete
Mortifying isn’t it! At least the cylinders may be an easier fix than the clutch itself?
What did you end up doing? Did you manage to continue on your trip?
Thanks for that link! That’s really handy. Will see what these guys see and then look at options.
Post #1041011 26th Jul 2024 7:34am
Dinnu
The slave cylinder on a Puma is as big of a job as replacing the clutch. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1041013 26th Jul 2024 7:38am
Bluest
Because it happened on a Sat afternoon (no chance of a garage) and we were about 3 hours from home we elected to abandoned the trip. Mine is going in for new master, slave/release bearing, clutch and LOF adapter shaft on Monday. I don't actually know what's failed yet, but everyone I've spoken to has said it likely the master or slave. Having everything else done just for piece of mind due to age?
Does your clutch pedal feel normal? Mine went soft and then stuck to the floor.
Slave cylinder is in the middle of the clutch in the bell housing, so not a quick job. Master is pretty straight forward I'm told.
Trying for Spain again in a couple of weeks. 2007 110 TDCi Station Wagon XS
Post #1041014 26th Jul 2024 7:46am
WestCountryPete
What a PITA having to abandon the trip. Sorry to hear that.
Clutch feels like normal. So still got some weight to it. Didn’t notice a rattle or anything on the clutch when idling (I always keep an ear out for that).
Post #1041015 26th Jul 2024 7:50am
BrickBox
If it’s the slave cylinder, unfortunately- you may as well do the clutch and everything while you are in there. Cheaper to do it all together now than taking the box off again in the future.
Go for the LOF Clutch bundle kit and one piece output shaft. You get the better 2.2 TDCi slave cylinder in the clutch bundle kit also. 2008 2.4 110 Utility Station Wagon XS.
Post #1041019 26th Jul 2024 8:37am
TexasRover
In a pinch you can drive a car with a failed (not disengaging) clutch. You have to start the car in 1st gear and work your way through the gears rev matching etc. Pain but on a motorway you can get pretty far without using the clutch.
The puma is in many ways a nicer defender especially for family vacations, but the Td5 is in many ways simpler, such as an external slave cylinder.
Post #1041020 26th Jul 2024 8:59am
Jabberwocky
Luxembourg
Wait, on the Puma you have to remove the gearbox to change the slave cylinder?🤷‍♂️🤷‍♂️ who thought that was a good design? And I though changing the one on the TD5 was awkward because the exhaust is a bit in the way.
Post #1042166 7th Aug 2024 11:48pm
90 Dreamer
majority of modern designs have a hydraulic concentric bearing so yes it's required to be internal to the gearbox........
Post #1042197 8th Aug 2024 8:28am
TexasRover
This was developed to have less components (cost) and no-one cares about the owner and their maintenance cost
Post #1042201 8th Aug 2024 9:06am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Gutted for you!
I had similar issue a couple of years ago - no symptoms and then suddenly not able to change gear with engine running.
If I remember correctly it was the spigot bearing that had failed. I had a new clutch fitted and unfortunately a new gearbox too as the spigot bearing had trashed the input shaft. Fingers crossed you won't need a gearbox!
Post #1042206 8th Aug 2024 10:31am
WestCountryPete
Sorry you had to go as far as replacing the gearbox!! I really hope that’s not the case for us!! Big Cry
The car has got to be left in France as there’s an issue getting a part, but honestly the work experience. The gearbox is out already so hopefully no further bad news other than the clutch.
Post #1042318 9th Aug 2024 1:16pm
Scotm
That was quick for them getting started!
Post #1042326 9th Aug 2024 2:56pm
WestCountryPete
The Landy is back on home soil!
Original repair time estimate was four days. Four WEEKS later we went and picked her up. Clutch works, so that’s good news at least. Not so good is that the transfer box now leaks and it’s picked up some electrical gremlins while in the French garages care!
Now it’s home I’m going to try and clean it up and see if I can work out what’s happening.
Post #1044171 28th Aug 2024 8:19pm
