Home > Puma (Tdci) > Unindentified broken wire - now solved :)
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Dear all, please help me out the next problim again..
Onedrive is not working (cannot login) so cannot go to the wire diagram.
I found a broken cable near to my transferebox. probably damaged when i but my geaarbox back in.
It has a bullit connector and calbe is white/yellow.
Any help apreciated.
It was indeed the handbrake warning light! thank you all
Post #1040567 21st Jul 2024 9:50am
ickle
I didn't think bullet connectors were used on the Puma, so possibly something aftermarket thats been removed?
HTH Keith
Post #1040570 21st Jul 2024 10:10am
TopQ1967
Thank you, but no it is in the original loom. it is only one cable no eart.
Post #1040572 21st Jul 2024 10:28am
Look for the other end would be a good idea, probably around the top of the trasfer box / bell housing area, it should have a female counterpart there somewhere.
Have you had any transmission work done? If so, likely disconnected and forgot to reconnect it.
Can be common after such a job, because it’s quite a long job to do so the final fitment fatigue sets in. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #1040586 21st Jul 2024 1:23pm
MK
hand brake Puma 110" SW
Post #1040590 21st Jul 2024 2:00pm
The only WY wire in the Puma electrical wiring manual is the wire that runs from the switch on the base of the handbrake lever to the infamous K109 header, located on the bulkhead behind the dash panel.
What is harder to explain is why your harness has a bullet connector since this (as commented above) there are - supposedly at least - none of these on the Puma, the connector at the handbrake lever should be a 6mm spade. Perhaps your harness has been cut and rejoined at some time in the past, or has had some other strange modification.
Post #1040602 21st Jul 2024 3:12pm
MK
Probably ROW spec, as all I have seen here are of this kind. Puma 110" SW
Post #1040603 21st Jul 2024 3:24pm
Interesting! I wonder why they are different.
Post #1040613 21st Jul 2024 5:03pm
MK
I think this clarifies it
 Puma 110" SW
Post #1040618 21st Jul 2024 5:27pm
This is where LR keep us on our toes, because there are subtle differences here and there. Laughing WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #1040621 21st Jul 2024 5:38pm
Martin
Site Admin
OK, so the Puma manuals are wrong, from the parts catalogue this connector (and link lead) carry over from the Td5 (and probably earlier models).
AMR3095/LR016446 is the link lead, which connects to the spade on the switch, the other end is a male bullet (as pictured in first post in the thread).
On the vehicle loom, somewhere near the transfer box, will be a female bullet.
This female bullet is the 'real' C0091 / part 13H5155 as it was on the Td5.
See 2002MY Td5 details: https://www.lrworkshop.com/connectors/defender-2002my/C0091  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1040626 21st Jul 2024 5:56pm
Puma manuals wrong? Who would have thought that was possible! Rolling with laughter
Well done for solving the mystery. Thumbs Up
Post #1040644 21st Jul 2024 7:55pm
