Home > Maintenance & Modifications > Trolley Jack!! |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4144 |
You could look at the sealey one and add the special jacking beam they do for Defender axles. I keeping thinking I'll get one but my current Jack won't die. 2007 110 TDCi Station Wagon XS
18th Jul 2024 4:53pm |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 291 |
Which model please
18th Jul 2024 4:57pm |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 137 |
I have a Halfords advanced 3 ton even has nice polyurethane wheels so doesn't sound like a jumbo jet making a low pass. Lofts my 110 up fine which is on standard HD suspension and 235 85 16s 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
18th Jul 2024 5:10pm |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 314 |
I got this jack and use the extension arm which gives 2 points of contact on the axle. It's been faultless so far.
https://www.toolden.co.uk/automotive/garag...SLEALw_wcB |
18th Jul 2024 5:19pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17192 |
The search button is always a good option:
https://www.defender2.net/forum/topic91448.html https://www.defender2.net/forum/topic79837.html Plus a few other threads. |
18th Jul 2024 6:16pm |
https://www.sealey.co.uk/product/563720780...or-3-tonne 2007 110 TDCi Station Wagon XS |
18th Jul 2024 6:32pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20033 |
Machine Mart is worth a look.
I use just the Hydraulic jack on the axle, I find it’s the safest option for me, but Trolley jacks have their uses and are faster / easier in other ways and in situations where there is a solid level floor. One benefit I can think of is faster to get a trolley jack underneath, but only in the right environment such as solid garage floor. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
18th Jul 2024 6:54pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 668 |
Bit pricey but a bit different too.
https://jcb-tools.co.uk/jcb-2-5-tonne-off-...-th32506s/ Click image to enlarge |
18th Jul 2024 9:51pm |
The JCB is similar to (but cheaper than) the stunning Pro-Eagle.
18th Jul 2024 10:31pm |
RDR Member Since: 27 Apr 2018 Location: Derbyshire Posts: 590 |
I have a few trolley off-road trolley jacks but have found i use this more nowadays easy to grab and sling under the vehicle and the added safety benefit of integral jack stand, high lift height too.
Click image to enlarge 110 MY23.5 X Dynamic HSE RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
19th Jul 2024 8:50am |
I like the idea of that. My Wife's car has nowhere to support the rear except the single lift point on each side so I always end with nowhere to put the stand once it is jacked up. 2007 110 TDCi Station Wagon XS
19th Jul 2024 8:22pm |
Interesting. Is it low enough to get under a Land Rover axle without jacking it up first? I’ve found them on Amazon but couldn’t see dimensions. Also worth noting that it is “ton” and not “tonne”. So only approx 1300kg for a 3 Ton rating. |
19th Jul 2024 9:20pm |
I'm not quite sure how you arrived at a figure of 1300kg. 1 ton = 2240 lbs (in the civilised world), 2000 lbs in the US. It's an American product. 1 tonne = 1000kg = 2200 lbs. The label on the device says "2721.5kg". |
19th Jul 2024 9:45pm |
My bad. Started writing it, then went off to do something before coming back to it and didn’t really read what I’d typed.
One of the listings for the item I was looking at says “3000lbs” which is 1360kg. The sticker does say 3 Ton which is 6000lbs. However I think axle stands (jack stands in the USA) are usually rated in pairs. Which would mean a single unit could explain the 3000lbs in the listing. Either way for someone in the U.K. the 3 Ton sticker could be misleading if you are thinking that as a single unit it’ll be fine for 3000kg. With my assumption being it is actually less than half this. |
20th Jul 2024 6:54am |
