Home > Maintenance & Modifications > Trolley Jack!!
roche1800
Trolley Jack!!
I am in the market for a new trolley jack. Looking around I think I need one with plenty of height for a Defender.
Any recommendations would be appreciated. Thanks
Post #1040242 18th Jul 2024 4:34pm
Bluest
You could look at the sealey one and add the special jacking beam they do for Defender axles. I keeping thinking I'll get one but my current Jack won't die. 2007 110 TDCi Station Wagon XS
Post #1040245 18th Jul 2024 4:53pm
roche1800
Which model please
Post #1040246 18th Jul 2024 4:57pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
I have a Halfords advanced 3 ton even has nice polyurethane wheels so doesn't sound like a jumbo jet making a low pass. Lofts my 110 up fine which is on standard HD suspension and 235 85 16s 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1040250 18th Jul 2024 5:10pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I got this jack and use the extension arm which gives 2 points of contact on the axle. It's been faultless so far.
https://www.toolden.co.uk/automotive/garag...SLEALw_wcB
Post #1040254 18th Jul 2024 5:19pm
The search button is always a good option:
https://www.defender2.net/forum/topic91448.html
https://www.defender2.net/forum/topic79837.html
Plus a few other threads.
Post #1040259 18th Jul 2024 6:16pm
Bluest
roche1800 wrote:
Which model please
https://www.sealey.co.uk/product/563720780...or-3-tonne 2007 110 TDCi Station Wagon XS
Post #1040263 18th Jul 2024 6:32pm
Machine Mart is worth a look.
I use just the Hydraulic jack on the axle, I find it’s the safest option for me, but Trolley jacks have their uses and are faster / easier in other ways and in situations where there is a solid level floor.
One benefit I can think of is faster to get a trolley jack underneath, but only in the right environment such as solid garage floor. NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #1040264 18th Jul 2024 6:54pm
Chicken Drumstick
Bit pricey but a bit different too.
https://jcb-tools.co.uk/jcb-2-5-tonne-off-...-th32506s/
Post #1040280 18th Jul 2024 9:51pm
The JCB is similar to (but cheaper than) the stunning Pro-Eagle.
Post #1040288 18th Jul 2024 10:31pm
RDR
I have a few trolley off-road trolley jacks but have found i use this more nowadays easy to grab and sling under the vehicle and the added safety benefit of integral jack stand, high lift height too.
 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV
D5 MY19 HSE - Now Sold
D4 MY16 HSE Luxury - Now Sold
D4 MY12 HSE - Gone
D3 MY06 S - Gone but not forgotten
Post #1040306 19th Jul 2024 8:50am
Bluest
I like the idea of that. My Wife's car has nowhere to support the rear except the single lift point on each side so I always end with nowhere to put the stand once it is jacked up. 2007 110 TDCi Station Wagon XS
Post #1040380 19th Jul 2024 8:22pm
Chicken Drumstick
Interesting. Is it low enough to get under a Land Rover axle without jacking it up first? I’ve found them on Amazon but couldn’t see dimensions.
Also worth noting that it is “ton” and not “tonne”. So only approx 1300kg for a 3 Ton rating.
Post #1040388 19th Jul 2024 9:20pm
Chicken Drumstick wrote:
...Also worth noting that it is “ton” and not “tonne”. So only approx 1300kg for a 3 Ton rating...
I'm not quite sure how you arrived at a figure of 1300kg.
1 ton = 2240 lbs (in the civilised world), 2000 lbs in the US. It's an American product.
1 tonne = 1000kg = 2200 lbs.
The label on the device says "2721.5kg".
Post #1040394 19th Jul 2024 9:45pm
Chicken Drumstick
My bad. Started writing it, then went off to do something before coming back to it and didn’t really read what I’d typed.
One of the listings for the item I was looking at says “3000lbs” which is 1360kg. The sticker does say 3 Ton which is 6000lbs. However I think axle stands (jack stands in the USA) are usually rated in pairs. Which would mean a single unit could explain the 3000lbs in the listing.
Either way for someone in the U.K. the 3 Ton sticker could be misleading if you are thinking that as a single unit it’ll be fine for 3000kg. With my assumption being it is actually less than half this.
Post #1040404 20th Jul 2024 6:54am
