Home > Modifications & Maintenance (L663) > Hitching on a caravan - any tips?
Ritson
France
Hi All
I've just picked up my new caravan and, as I suspected, its a bit of a nightmare hitching it on and taking it off because the spare wheel hangs directly over the hitch, making it extremely awkward to raise the Alko stabiliser high enough to subsequently raise the hitch lever to engage/disengage the tow ball. I can't open the rear door fully to gain easy access as it won't pass the jockey wheel.
Has anyone out there come up with a solution?
Cheers Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #1039272 6th Jul 2024 11:51am
Pitcaig
Just remove the bolt from the stabiliser handle so that you can remove it. It then fits easily under the spare wheel.
Just slide the handle back on to either put the tension on or to remove the tension
Post #1039304 6th Jul 2024 7:41pm
Ritson
France
Absolutely genius! I'd never have thought of that, thanks very much Thumbs Up Current: MY22 P400e SE
Post #1039305 6th Jul 2024 7:44pm
LR Nuts
If you have air suspension, use the two buttons in the load space.
Post #1039306 6th Jul 2024 8:01pm
Ritson
France
Yes I have air suspension, but that doesn't change the height between the spare wheel and the tow bar unfortunately. Current: MY22 P400e SE
Post #1039308 6th Jul 2024 8:06pm
Gareth
Our Elddis has a BPW hitch with a long handle. I do it is as follows:
Open the rear door
Reverse up to the caravan using the towing camera. The door doesn’t hit the caravan. Make sure the front locker is closed.
Hitch the van to the car.
Close the door
Raise the jockey wheel and connect electrics and break away cable.
To unhitch.
Drop the jockey.
Open the door.
Unhitch the caravan.
Roll the car or caravan apart
Close the door. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1039311 6th Jul 2024 9:20pm
Ritson
France
Thanks Gareth. I'll try that approach but Im pretty sure no matter if my jockey wheel is fully lowered the door still hits the handle Current: MY22 P400e SE
Post #1039313 6th Jul 2024 9:37pm
lightning
l've had the same issue with my 90.
The way l do it is to open the rear door, reverse the Defender up to the caravan, attach the caravan, raise the jockey wheel fully, lower the jockey wheel carrier enough so the handle doesn't hit the bottom of the door, close the rear door, then raise the jockey wheel carrier to the transport position.
Post #1039314 6th Jul 2024 9:52pm
Huwrhys
I had a hell of a job removing the ALKO black plastic handle from my 8 year old Vanmaster. I ended up cutting it off. I managed to get the push on ALKO handle from a guy on here for less than the cost of replacing the plastic bit.
 24MY D300 130 X-Dynamic HSE Santorini Black
Post #1039414 8th Jul 2024 7:40am
Pitcaig
Okay.
Once I had taken the bolt out mines just slid off. I’ve got to remember to remove it when I’m towing so it doesn’t fall off and get lost.
I did try the reversing back with the door open but that only works if you can go straight back. If you go at an angle so you are pointing right the door can hit the caravan. Also it didn’t work for me as I have the dog in the back most times and I can’t trust her to not try and jump out. So for me removing the handle works the best.
Post #1039417 8th Jul 2024 8:18am
Ritson
France
That seems an ideal solution, but I can't find one for sale on the internet anywhere Sad Current: MY22 P400e SE
Post #1039432 8th Jul 2024 10:03am
Huwrhys
https://www.facebook.com/groups/1490875485...188515430/
Found this but not sure if it's there still. May be worth a punt.
Also worth calling some caravan suppliers to see if they hold old stock. I looked for new initially and did find one but it was £75. I then found one on here thankfully.
Part number is ALKO 1287287. 24MY D300 130 X-Dynamic HSE Santorini Black
Post #1039437 8th Jul 2024 10:37am
Ritson
France
Thanks
I'll try some of the caravan dealers here in France but it looks like its a discontinued part. Fingers crossed the method of backing up the car with the door open will work, will try as soon as I go up to the caravan storage.
Post #1039439 8th Jul 2024 11:09am
lightning
Why not try what l suggested above. No need to remove the handle.
Post #1039492 9th Jul 2024 9:14am
Ritson
France
Hi Lightning
I will try your method once I go back to where the caravan is in storage. However, I'm pretty sure even with the jockey wheel fully wound up, then lowered the handle still catches the door, lets hope I'm wrong as it would be a lot easier if this method works
Post #1039493 9th Jul 2024 9:38am
