Home > Maintenance & Modifications > Unused space in RH wing (RHD vehicle)
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
I removed the trim panel from the RH wing of my 300TDI Defender (where heater inlet would be on LHD vehicle) and was surprised how much of a void is in there. Probably enough to allow storage of wheel changing tools and a tow strop.
With a hinged lid the some items could be removed with the bonnet closed.
Have any of you made such a modification?
The challenge really is installing panels to stop the items escaping into the engine area followed by preventing them from rattling around.
Post #1039017 3rd Jul 2024 11:56am
MK
Some space on the LHD too, eg. my ARB difflock compressor fits there. Puma 110" SW
Post #1039022 3rd Jul 2024 12:24pm
This sort of thing has been available for years:
https://www.mudstuff.co.uk/products/nakata...der-locker
Cheaper (inferior) versions are also available from popular online auction sites etc.
Post #1039027 3rd Jul 2024 12:47pm
MercianRover
There's significantly more accessible volume than that tiny trapezoidal box affords access to, I'd suggest in the region of 30 litres useable void as far forward as the back of the headlamp and aft to the footwell.
On the LHS there's the volume from the heater air inlet duct to behind the headlamp but it's more suited to items like an air compressor which one reply mentioned.
As to LHD vehicle I suspect it's a mirror image: same volume different side.
I'll do some measuring later. I think a 25mm steel mesh might make a good seperator from the engine bay and allow warm air to circulate hopefully drying things off when the weather is fair.
Post #1039033 3rd Jul 2024 1:55pm
Bluest
I used that space to mount an auxiliary fuse and relay box for the lights at the front of the car. It looks after the headlight relay loom and auxiliary driving lights. Its a good place to get a live feed direct from the alternator and there is some spare capacity in there for other things in the future. 2007 110 TDCi Station Wagon XS
Post #1039036 3rd Jul 2024 2:25pm
Chicken Drumstick
Any links to the cheaper ones? Looked on eBay but couldn’t get any hits for Defender locker/wing storage etc. Thanks.
Post #1039042 3rd Jul 2024 3:20pm
Looking slightly more closely to the result of my quick Google earlier, it appears that the cheaper ones are for LHD vehicles. I cannot immediately find any for RHD.
Post #1039043 3rd Jul 2024 3:49pm
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Watching this as I had plans to try and fit an ARB compressor in that space Wink
Post #1039046 3rd Jul 2024 4:05pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Good idea for locating a compressor in there. I've been struggling where to fit one in.
Post #1039109 4th Jul 2024 9:18am
macfrank
Watching with interest Smile Been contemplating this for years. One question was how to get a container in there without removing the wing. I like the steel mesh idea! Then, if needed, stuff a rugged bag inside.
Next question was how to make a lid. I don't like the naka type ones (gmb-mount does one, too). Thought about just reusing the original cover, but with magnets. Would it stick on a corrugated road?
This is "Willy the Defender". The owner removes one screw and the lid swivels around another screw to open. The other screws are just the heads, glued in Smile
(I drew the red arrow the wrong way but you get the idea Smile )
Post #1039171 4th Jul 2024 9:43pm
Zimblewinder
Australia 2000 Defender 130 2.5 TD HCPU Chawton White
Ive seen people over here (oz) mount their winch solenoids there. Plan to do the same with mine.
Post #1039174 5th Jul 2024 7:05am
MercianRover
Maximum depth at each end is 250mm
Minimum is ab out 120mm by the top of the arch.
Useable length is 750mm measuring the curved flange inside the wing from by the radiator to approx centreline of the brake servo.
Plan is to secure the mesh to the return flange on the top face to which the header tank and fuel filter are secured thence to the inner wing by P clips and pop rivets.
I'll use some mesh with wire around 18 to 14SWG (1.2 to 2mm) diameter.
The jack can go on a bracket by the footwell end which will also carry it's handle and the wheel brace.
I think the rest of the volume can hold the tool roll and spares, prbably secured by some footman loops to stop any jiggling denting the outer wing skin.
Post #1039303 6th Jul 2024 7:37pm
