Home > Faults & Fixes (L663) > Driver and front passenger door rattle |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 41 |
Try this solution. I had a similar sound and this solved it.
Take the overhead grab handles off. When pulling them out you will notice that they have tabs on them to allow them to be installed with the headliner at the factory. Those little tabs are the cause of rattles. They click against the headlining and make noise. You have two options. One is to just wrap the tabs in duct tape and reinstall the handles. The other is to cut the tabs off and reinstall the handles. They don't do anything other than allow the handles to be installed with the headlining at the factory. Took me a couple months of chasing phantom noises before I honed in on this as the problem. Instant relief once I fixed it. |
3rd Jul 2024 9:49pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 158 |
hi thanks for the advice,
I'm very interested too, when you talk about handles do you mean external door handles? Thanks Marco |
9th Jul 2024 7:22pm |
@mmbanf - Not the door handles, but the grab handles in the headliner.
That noise can sound like it's coming from anywhere about shoulder height and up. |
9th Jul 2024 7:28pm |
HI ,
thanks I understand, the handles on the headliner Thanks |
9th Jul 2024 8:06pm |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 121 |
Aka "Jesus bars".
11th Jul 2024 5:17am |
TSY Member Since: 27 Feb 2024 Location: Colorado Posts: 11 |
I had this problem (now past tense). If there are any lingering questions - Simon (PowerfulUK) removes them in a swap kit, and you can easily see the offending tabs in question.
9th Sep 2024 10:13pm |
