Home > In Car Electronics > USB Charger tripping on ignition
AMBxx
I bought a nice USB charger from MUD : https://www.mudstuff.co.uk/products/usb-an...5964364885
It's connected to a voltage sensing relay.
Each time I turn on the ignition, I need to reset the charger with the little button as it trips.
Mud have been good enough to send me a 2nd to check the problem is not with the USB charger. It's definitely a problem with my electrics.
Is there something I can put into the circuit to stop the thing tripping every time? I wouldn't mind so much but it's on the back of the cubby box so a pain to reach (it's for my wife's phone...).
Alternatively, I could run another wire from permanent live.
Post #1038346 25th Jun 2024 9:38am
MadTom
Check, if you are not just switching the power off for short time during ignition switched to crank engine. It is common to switch off lot of power consuming parts during engine cranking to conserve power. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1038352 25th Jun 2024 10:15am
AMBxx
Not sure what you mean.
There's a small button on the USB charger that I assume is the equivalent of a fuse. That trips every time. The only way to make the charger work is to reset by pushing the button.
Post #1038355 25th Jun 2024 10:36am
jst
the on/off button rather than trip on the usb charger.
what exactly is it connected to on the VSR? i would suggest, as mentioned above, what ever it is connected to looses its 12v supply on cranking.
just connect it straight to perm 12v. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1038359 25th Jun 2024 12:01pm
Mo Murphy
As James has said, straight to permanent 12v.
50 Shades of Pennine Grey
Post #1038365 25th Jun 2024 1:15pm
rallysteve
Assuming the VSR is not energised until the engine starts anyway (i.e. when the battery voltage is >13v)?
The button on that USB is just a momentary on/off button so it no doubt defaults to 'off' whenever power to it is cycled. If you want it switchable then as said above, needs a constant supply. Otherwise use a version without the on/off switch.
Post #1038369 25th Jun 2024 1:36pm
MadTom
Look for USB charger with rocker switch instead of on with push button switch. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1038452 26th Jun 2024 10:44am
AMBxx
I see my mistake now. I thought the button was the equivalent of a fuse, not an on-off switch. Banging Head
I'll wire it in permanently or see if I can disable the switch.
thanks all for the feedback.
Post #1038462 26th Jun 2024 12:32pm
MadTom
With USB charger connected to 12V all time look for current consumption of the charger itself - is can drain battery, when the car is not used for longer time. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1038739 29th Jun 2024 7:25pm
