Home > Maintenance & Modifications > Diesel Pre Filter - Any ideas?
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
I'm planing some remote global travel, and see a few other travellers with other cars fit pre filters to filter dodgy diesel before the main filter.
Is there a kit out there local in the UK, or what have other folks done? This is for a Puma 110, 2010 2.4 model.
Any advice/ideas would be great.
Thanks
John
Post #1037934 20th Jun 2024 11:18am
Jabberwocky
Luxembourg
Give Paul Foley a ring, he has direct knowledge of Defenders in Africa, Foleys still have an operation in Kenya, run now I think by Paul’s son. I did have a chat with Stuart foley about this as we are going to travel down the west coast of Africa in a TD5 and his advice was a TD5 will be fine, just have a few spare filters to change regularly. From what I remember about our conversation they do recommend a pre filter for the puma engine.
Post #1037969 20th Jun 2024 8:18pm
MK
a few kits over the internet, leaving the OE filter as prefilter (5um) and a final 2um filter. Puma 110" SW
Post #1037979 20th Jun 2024 11:09pm
spudfan
Ireland
I have seen some large tractors with two fuel filters side by side. I have heard it said that the Defender might not be able to draw the fuel through the two filters so just check that out. You can fit a sedimenter in line. It is a glass bowl type filter that traps water and will extend the life of the diesel filter. My series 111 2.25 diesel has one so they must have been standard fit at one time.
. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1038020 21st Jun 2024 11:58am
shaynecm
you want a sedimentor between filter/tank you can get twin ones too for extra security - get a glass bottom so you can see into it and fit in engine bay and not onto chassis. so its better protected.
https://www.force4.co.uk/item/Delphi/Water...isQAvD_BwE
https://www.ebay.co.uk/itm/284401523398?va...58QAvD_BwE
some people have fitted dual filters too as alternative.
Post #1038023 21st Jun 2024 12:46pm
