Home > Maintenance & Modifications > Diesel Pre Filter - Any ideas? |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 212 |
Give Paul Foley a ring, he has direct knowledge of Defenders in Africa, Foleys still have an operation in Kenya, run now I think by Paul’s son. I did have a chat with Stuart foley about this as we are going to travel down the west coast of Africa in a TD5 and his advice was a TD5 will be fine, just have a few spare filters to change regularly. From what I remember about our conversation they do recommend a pre filter for the puma engine.
20th Jun 2024 8:18pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2386 |
a few kits over the internet, leaving the OE filter as prefilter (5um) and a final 2um filter. Puma 110" SW
20th Jun 2024 11:09pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4615 |
I have seen some large tractors with two fuel filters side by side. I have heard it said that the Defender might not be able to draw the fuel through the two filters so just check that out. You can fit a sedimenter in line. It is a glass bowl type filter that traps water and will extend the life of the diesel filter. My series 111 2.25 diesel has one so they must have been standard fit at one time.
Click image to enlarge Click image to enlarge . Click image to enlarge Click image to enlarge . 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
21st Jun 2024 11:58am |
shaynecm Member Since: 10 May 2024 Location: Norwich Posts: 62 |
you want a sedimentor between filter/tank you can get twin ones too for extra security - get a glass bottom so you can see into it and fit in engine bay and not onto chassis. so its better protected.
https://www.force4.co.uk/item/Delphi/Water...isQAvD_BwE https://www.ebay.co.uk/itm/284401523398?va...58QAvD_BwE some people have fitted dual filters too as alternative. |
21st Jun 2024 12:46pm |
