![]() | Home > In Car Electronics > Heated mirror wire routing |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 469 ![]() ![]() |
Usually use the later Defender door trunking and then just run up through the bulkhead with the courtesy light switch wiring.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5798 ![]() ![]() ![]() |
Later Defender door trunking?
I was looking at buying/fitting the rubber door to bulkhead tubes to hide the wires. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Yep YQQ000070 X2
Cheers. 1999 Defender TD5 110
