![]() | Home > Puma (Tdci) > 110 standard height |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 910 ![]() ![]() ![]() |
Do you have a picture to upload? 2008 2.4 110 Utility Station Wagon XS.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1207 ![]() ![]() ![]() |
This information is readily available online. Note however that there are different rear spring setup giving a different ride height aft for the 110 (commercial, pickup, Country SW)
Also you want to check your tire size, someone might have put on bigger ones. |
Phillywilly72 Member Since: 29 Apr 2024 Location: Wiltshire Posts: 77 ![]() ![]() ![]() |
![]() Click image to enlarge Pics for ref ![]() Click image to enlarge |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 719 ![]() ![]() ![]() |
This might help: https://gwynlewis4x4.co.uk/fitting-instructions-tech-info/
There's a download called 'How to measure you suspension...' 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Brill cheers. I have read though that different 110 models have different set heights I guess due to weight differences of pickup, dcpu etc
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
https://www.defender2.net/forum/post708517.html Puma 110" SW
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17674 ![]() ![]() ![]() |
The DCPU always has a bum-in-the-air stance due to having springing for a 1-tonne payload. It's a choppy ride when empty!
That makes sense. Is there any way of identifying if HD springs have been used? Like diameter of the coiled metal or more turns per height?
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 821 ![]() ![]() ![]() |
Springs are colour coded see below.
From your picture Looks standard height to me., ![]() Click image to enlarge |
