Home > Technical > 2022 P300 Oil Change |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 995 |
Although it is satisfying to see hot oil gush out of the drain, sucking it out is way more easy and convenient. I had a few LR3 and 4 and they have skid plates which makes it even more cumbersome to get to the drain plug so I bought a large sucker. One day I tried to see how much was left behind the drain plug and not a drip came out.
In the end if you change frequently enough there will be no sludge and you just replace 99% of the dirty oil with new fresh oil. So for your convenience I would say extract the oil by suction and replace with correct oil and you be doing your engine a huge favour. |
29th May 2024 6:12am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 411 |
Make it yourself easy and install the Fumoto drainplug .
See this thread on Landrover forums.com I did make one hole wider in the under plating for even quicker draining with a tube. https://landroverforums.com/forum/2020-def...post884592 No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
29th May 2024 8:58am |
